denamy1
Apr 11, 2015Explorer
Dish satellite hookup via cable input on Travel Trailer
After reading many posts, today I hooked up my "Dish Tailgater" satellite using the existing "cable input" on my Coachman Travel trailer. It was rather simple.
My travel trailer did not come with a satellite exterior hookup, just the cable input, so here is what I did.
As you know, plugging in the satellite receiver via the powered antenna RG6 coax plug WILL NOT WORK. So.. I bought a "diplexer" which looks like a splitter but is not a splitter. It has three ports: in/satellite/VHF. I removed the coax cable coming from the travel trailer's outside cable port and connected that to the "in/out" of the diplexer, then hooked up a short coax from the UHF on the diplexer to the powered wall plate. I then hooked up the satellite box to the "satellite port on the diplexer. Bingo.. everything worked.
The whole idea is to put the diplexer in between the coax coming in from the outside of the rv and the powered wall plate. This allows you to use either the TV OR satellite. I did not have to run a new coax like some people posted.
By the way the diplexer cost me 5 bucks on Amazon.
