thehippie's avatar
thehippie
Do I need a weight distribution hitch?
Do I need a weight distribution hitch? The trailer weighs 3980 pounds (which is more than half the weight of a 2015 ram 2500 cummins tow vehicle) w/ 510 pounds tongue weight
There's no wd hitch in the pic but has a sway friction control bar
  • My trailer is 6k-7k (depending on toys) with more tongue weight than what you've got. I do not use a WD hitch.
  • I had the same discussion about my 3/4 ton truck and the trailer weighted at 6,500 pounds empty. Most members said I did not need it. However, I negotiated with the dealer to include one for free. I towed both ways and I noticed no difference. Sway controller will be a benefit though.
  • Ivylog's avatar
    Ivylog
    Explorer III
    No, you need all of the 510 is needed on the rear axle.
  • WD hitch is there to balance or shift part of the load to the front axle. Weights when fully loaded will tell the tale.
  • I doubt it. Looks like you are fine. As long as your sway control works.
