Bobbo
Jul 24, 2018Explorer III
ktmrfs wrote:
Now the newer honda 2200 have a "run dry" feature you can use when you shut it down to keep the generator running till it runs out of fuel in the carb. It shuts off the fuel pump.
You easily add the same feature to an older honda 2000 as well.
I added this "run dry" feature to my Honda 2000. I bought this Shut Off Switch. I unplugged the wire that grounded out the generator and replaced it with this switch. If I leave the switch ON, the generator now runs till it runs out of fuel. I have the option of turning the switch off for immediate shut down. (The switch is currently inside the generator case. When the generator is out of warranty, I will drill a hole and mount it.)
About RV Newbies
