jake2250
May 16, 2016Explorer
orggardn wrote:
Well, I'm buggered off..... only once since I installed my Tornado rinsing system into the black tank, have I found a hose at the dump station with threads. Every other time, the hose end has been cut. I'm assuming to prevent really rude people from taking way too long to try and clean every particle out of their tanks.
I have a Water Thief connected to the Tornado and try to jam it onto the hose, but the back pressure blows it off every time. I try and hold it with my hands, but usually end up getting drenched as the pressure is just too much. I've tried crimping the hose and throttling the pressure, but that has had limited success.
Am I missing something? I really want to use the system, as that one time (and a choice few when I could "hold" the Water Thief on), it really pushed a lot more out of the tanks.
Appreciate your help......
**NOTE: I am NOT going to haul buckets of water in and out of the trailer at the dump station. I really need a "connection" option to work.
Well it looks as though these should be outlawed as they create Butt Hurtfulness!! The mere sight of this appliance suggests that you are screwing every one else behind you!!
Even the campground is against you by cutting the male threaded end of the hose off!!
Even though you believe you are doing the right thing and have the right to do so..
Nothing says on the user information to Not use when other campers may be near!
Illegal for use
But hey,, this was a fun thread,, some really showed their true colors..
And for goodness sake,, Turn off your awning lights!!
About RV Newbies
