Vulcan_Rider
Sep 05, 2015Explorer
Nothing will freeze until the temp gets below 32 and stays there for several hours.
Even then, nothing will likely be damaged IF no pressure builds up.
I think if you heat the cabin, turn off the water pump and leave the faucets open you should be fine. Leaving the hot water heater on if you can would be good too.
About RV Newbies
