- sayoungExplorer
westend wrote:
Kansas Driver's Handbook--Page 2 has the breakdown of licenses by class of motor vehicle.
same license wieght rules we have,just worded a different way.
OP just needs to know the GVWR of the MH and if towing anything the combined GVWR.If over 26K lbs total then a Kansas A or B non-com.
Its allways in the states DL handbook - GreentowExplorerMay different states have different terms.... I don't know. My Delaware License is a CDL Class A, that lets me drive tractor trailer. A Class B is for straight truck, OVER 26,001 pounds. Some states now require "endorsements" and/or a NON-CDL for weight or length or both. As the saying goes, "It's a crap-shoot out there", but whatever is valid in YOUR HOME STATE, is good throughout the rest of the states.
- sayoungExplorer
Jim-Linda wrote:
sayoung wrote:
Jim-Linda wrote:
The B restricts you to a 10K lb max trailer behind your rig,why I got the A,same test/money to TxDPS.sayoung wrote:
curlysue321 wrote:
With a 34-38 foot class A does one need a special driver's license?
I can only speak for Texas residents,here if your GVWR exceeds 26000 lbs(wieght not length) then you need a Class A non-commercial.get your states drivers handbook for both non-commercial and commercial and read up.
Actually, for a single vehicle(Class A) that's over 26K a Class B exempt is what you need.
Jim
He was asking about a MH, not about a trailer.
Jim
Its the GVWR of the vehicle and the GVWR of any attached car/trailer and even with a MH you probably are pulling a car or trailer sometimes so your combined rating is what determines if you need A B or C,IN TX.Tx adopted the FED regs as told to me by my friend the TxDPS compliance officer.
when reading any states license handbook,read furthur than the 1st reg you come to that says what you want to hear,our state handbook has "exemptions" then you get to the "exceptions to the excemptions" which starts at the magic 26000 LB GVWR limit of private vehicles driven with a C license.Now whether you will ever be gigged for non compliance is another thread. - Jim-LindaExplorer II
Jim
Jim - westendExplorerKansas Driver's Handbook--Page 2 has the breakdown of licenses by class of motor vehicle.
- BumpyroadExplorer
fyrflie wrote:
Since nobody really answered your question, I will take a stab at it.
Here is what I found on the California DMV website.
www.dmv.ca.gov
Its longwinded but the answer to your question is NO.
Class C driver license -
•You may drive a: ?2-axle vehicle with a Gross Vehicle Weight Rating (GVWR) of 26,000 lbs. or less.
?3-axle vehicle weighing 6,000 lbs. or less gross.
?Housecar 40 feet or less.
?3-wheel motorcycle with two wheels located in the front or back.
?Vanpool vehicle designed to carry more than 10 persons, but no more than 15 persons including the driver.
NOTE: The vanpooldriver must have a valid medical certification on file with the DMV and carry a valid medical card. The driver must keep in the vanpool vehicle a statement signed under penalty of perjury, that he or she has not been convicted of reckless driving, drunk driving, or hit-and-run in the last five years (CVC §12804.9(j)).
•You may tow a: ?Single vehicle with a GVWR of 10,000 lbs. or less, including a tow dolly, if used.
•With a vehicle weighing 4,000 lbs. or more unladen, you may tow a: ?Trailer coach or 5th-wheel travel trailer under 10,000 lbs. GVWR when towing is not for compensation.
?5th-wheel travel trailer exceeding 10,000 lbs. but under 15,000 lbs. GVWR, when towing is not for compensation, and with endorsement.
•A farmer or employee of a farmer may drive: ?Any combination of vehicles with a GVWR of 26,000 lbs. or less, if used exclusively in agricultural operations and it is not for hire or compensation.
NOTE:
•Class C licensees may not tow more than one vehicle.
•A passenger vehicle, regardless of weight, may not tow more than one vehicle.
•A motor vehicle under 4,000 lbs. unladen weight may not tow any vehicle weighing 6,000 lbs. or more gross. (CVC §21715)
and this applies to Kansas because?
bumpy - fyrflieExplorer IIISince nobody really answered your question, I will take a stab at it.
www.dmv.ca.gov
NOTE:
•A motor vehicle under 4,000 lbs. unladen weight may not tow any vehicle weighing 6,000 lbs. or more gross. (CVC §21715) - mowermechExplorer
I doubt if it will do you any good, but in Montana, no. - sayoungExplorer
Jim - BumpyroadExplorer
Wadcutter wrote:
Having spent 42+ yrs in LE and answering questions from the public on almost a daily basis I learned early on that a lot of people really don't want the correct answer. They only call trying to get someone to agree with them. If you tell them something other than what they want to hear then they'll spend a great deal of effort trying to convince you to agree with them.
that is very true for this forum. lots of "will my edsel pull a 45 ft TT", etc. can I tow a mercedes xxx 4 down, etc. hoping to get "approval' here. and unless you get the answer in writing from the DMV it is more or less worthless.
bumpy
About RV Newbies
4,032 PostsLatest Activity: Aug 28, 2025
