- Cristian123ExplorerI had only a Class B licence when I wanted to buy an RV. So, I had to pass PCV theory test. By the way, I found the way to practice online (in case you are interested, check this source). And it should be mentioned that you have to be 18 to get this type of license.
- sayoungExplorer
philh wrote:
DrewE wrote:
It would appear that one still only needs a standard operator's license, as far as I can make out from the web sites, but if you're in or about to be in that particular set of circumstances it would behoove you to enquire at the appropriate government offices. They do explicitly say you don't need a CDL, as is true everywhere; and as there don't appear to me to be any other applicable non-commercial license classifications, I gather that a standard license is all that is required. (There is an additional endorsement needed for recreational double towing--i.e. a fifth wheel RV plus some other trailer.)
I did check and they explicitly stated I don't need a CDL... however, I have learned to never trust this as being legal advice. Reading the plain language of the statute, it appears there's a hole in the published law.
Could be like here in Tx. On first page of commercial handbook says RV's exempt. Then several paragraphs into the regs is the " exceptions to the exemptions " and there is the >26000 lb rules for non-CDL requirements of the higher weights. - shum02Explorer
IB853347201 wrote:
wa8yxm wrote:
Some states require a special endorsement. Some require it if you are over xxxxx pounds... And the number of pounds varies from state to state. YOUR HOME STATE (That is the one that issues your license) makes the decidsions.
EXAMPLE. at Less than 26,000 pounds from Michigan I need only an "Operators" (Standard Driver's license)
IN Texas over 26000 pounds I'd need an endorsement. Under 26000 I do not know. Actually I do not know if it's 26000 pounds either.
In Ontario, with a regular license, Class G, you are allowed to drive any car, van or small truck or combination of vehicle and towed vehicle up to 11,000 kilograms, 24,310 lbs., provided the vehicle towed is not over 4,600 kilograms. A pickup truck towing a house trailer exceeds 4,600 kilograms, but the total combined weight of the truck and trailer does not exceed 11,000 kilograms is deemed a Class G.
If you drive a MH exceeding 11,000 kilograms, 24,310 lbs, or your registered gross weight or any combination including your trailer or toad is over 11,000 kgs provided the towed vehicle is not over 4,600 kilograms, you need a Class D license.
License regulations and classes are similar in many other provinces and states.
YMMV with this as well. I would stick to the 11k kilo GCVWR with G lic though just for safety sake. - CampinghossExplorer IIIn NC if your motorhome is over 26000 you are suppose to get your license upgraded to a B instead of C. That is what I did when I had my dp. I also got my air brake endorsement. I expect you just need to check with your state DMV.
- philhExplorer III
I did check and they explicitly stated I don't need a CDL... however, I have learned to never trust this as being legal advice. Reading the plain language of the statute, it appears there's a hole in the published law. - Edd505ExplorerNot all states do but they should, for any type RV. Driving an A,b,C, or pulling a TT or 5W all need skills not used driving the family car. The biggest is you can not see what directly behind you as the rear view mirror is useless.
- doxiemom11Explorer IIIt depends on what state you are in as each has it's own requirements, or nothing special . Check with your licensing department for your state.
- DrewEExplorer III
philh wrote:
What happens if it's a Truck and 5th over 26k, but still privately owned?
It would appear that one still only needs a standard operator's license, as far as I can make out from the web sites, but if you're in or about to be in that particular set of circumstances it would behoove you to enquire at the appropriate government offices. They do explicitly say you don't need a CDL, as is true everywhere; and as there don't appear to me to be any other applicable non-commercial license classifications, I gather that a standard license is all that is required. (There is an additional endorsement needed for recreational double towing--i.e. a fifth wheel RV plus some other trailer.) - sayoungExplorer
Captain_Happy wrote:
You need to check with your own state DWV requirements. Every state is different.
Exactly what you have to do. My state requires an A non-CDL if combined gvwr exceeds 26000 lbs. It's not enforced except if a major problem occurs. - philhExplorer III
About RV Newbies
