- Dutch_12078Explorer IIII've driven several people to the NY DMV 'R' endorsement road test. They've all told me it was even simpler than the standard car license driving test. I have the 'R' endorsement although my current rig doesn't require it, but I got mine on request when I dropped my fully endorsed CDL. No road test needed.
- wa8yxmExplorer III
gbopp wrote:
Ava wrote:
In Canada if you have a rig with air brakes, you need an air brake endorsment on your license. Not sure about different US states
I think Pennsylvania requires an Air Brake Endorsement.
Remember My "Your millage may vary" comment.
now why woudl Pa require me to have an air brake endorsement for my 38' Class A.. It's a gasser. Hydraulic brakes.. NOT AIR. - CA_TravelerExplorer IIIStates vary. Check with your resident state and that license is valid in any state you drive in. ie License reciprocity applies.
- Grit_dogTrailblazer
Captain_Happy wrote:
You need to check with your own state DWV requirements. Every state is different.
This is the succinct and accurate answer is this ^.
But thanks to the others who somehow feel an overtly literal or condescending response was warranted. - IB853347201Nomad II
wa8yxm wrote:
Some states require a special endorsement. Some require it if you are over xxxxx pounds... And the number of pounds varies from state to state. YOUR HOME STATE (That is the one that issues your license) makes the decidsions.
EXAMPLE. at Less than 26,000 pounds from Michigan I need only an "Operators" (Standard Driver's license)
IN Texas over 26000 pounds I'd need an endorsement. Under 26000 I do not know. Actually I do not know if it's 26000 pounds either.
In Ontario, with a regular license, Class G, you are allowed to drive any car, van or small truck or combination of vehicle and towed vehicle up to 11,000 kilograms, 24,310 lbs., provided the vehicle towed is not over 4,600 kilograms. A pickup truck towing a house trailer exceeds 4,600 kilograms, but the total combined weight of the truck and trailer does not exceed 11,000 kilograms is deemed a Class G.
If you drive a MH exceeding 11,000 kilograms, 24,310 lbs, or your registered gross weight or any combination including your trailer or toad is over 11,000 kgs provided the towed vehicle is not over 4,600 kilograms, you need a Class D license.
License regulations and classes are similar in many other provinces and states. - magicbusExplorer IIFrom your New York DMV:
"A driver with a Class D license can now operate a personal use vehicle (for example a rental vehicle or a recreational vehicle or RV) with a gross vehicle weight rating (GVWR) of 26,000 lbs. or less that tows another vehicle that has a GVWR of 10,000 lbs. or more, but the gross combined weight rating (GCWR) of the two vehicles together must be 26,000 lbs. or less.
Note: The requirement for an "R" endorsement (Class D or Class E license) to operate a recreational vehicle with a GVWR of 26,001 lbs. or more remains in effect."
From another site, the "R" endorsement is apparently a driving test to show proficiency but I can't seem to find that information on the NY DMV site.
Dave - Captain_HappyExplorerYou need to check with your own state DWV requirements. Every state is different.
- gboppExplorer
I think Pennsylvania requires an Air Brake Endorsement. - wa8yxmExplorer IIIMost of the web pages I've seen about RV related legal stuff like
"Do you need a special license"
Or
What can you tow (single or double)
Or
DO you need brakes on the trailer
All have errors.
This is the only answer I'd trust: Your millage may vary.
By that I mean the answer depends on WHERE you live and WHAT you drive/tow
IN Texas over 26000 pounds I'd need an endorsement. Under 26000 I do not know. Actually I do not know if it's 26000 pounds either. - bikendanExplorer
frankgibbons1947 wrote:
I was searching in the forums related to a topic regarding the special license required to drive an RV.
Unfortunately, nothing shows up. So, I've decided to create a topic about it.
If you’re looking at an especially large RV, it is important to note that there are a few states that will require a special license. Read more.
In case you don't know, motorhomes/5th wheels/travel trailers/popups/truck campers are all considered RVs.
About RV Newbies
