- Dutch_12078Explorer IIIAre you sure it's not a heat pump?
- ependydadExplorerAs mentioned, fan's set to low or high. This question is frequently asked and I have an article about it:
https://learntorv.com/help-ac-comes-on-when-heat-comes-on/ - ktmrfsExplorer IIIjust went through the same issue with my brother on his trailer with the dometic thermstat and AC. yup, set it to auto made it work like one would expect.
oh, and if for some reason the display changes to degrees C instead of Degrees F, (or vice versa) push the up and down together and hold and it will switch. - thehippieExplorer
A1RVTraveler wrote:
Thanks
Go to the wall thermostat and push the Mode button until the green light is on in the Fan Position. Use the +/- arrow to move the selection to Auto. You currently have it set to LO or HI. - thehippieExplorer
AVid wrote:
Thanks
Place the fan control on the thermostat on "AUTO". - thehippieExplorer
Old-Biscuit wrote:
YEP^^^
Fan control on thermostat is for the A/C Unit Fan.
In Auto the Fan runs when A/C runs
In Manual (high or low) fan runs when A/C runs BUT will also run when furnace runs.
Idea is A/C Fan 'helps' circulate the warm air from furnace (heat rises)
But in reality it just cools the wram air and provides no benefit plus it's noisey. - A1RVTravelerExplorerGo to the wall thermostat and push the Mode button until the green light is on in the Fan Position. Use the +/- arrow to move the selection to Auto. You currently have it set to LO or HI.
- DrewEExplorer IIIIs the "Dometic heater" perchance a heat strip on the air conditioner? If it is, the fan needs to run for the heat to work.
- Old-BiscuitExplorer III
YEP^^^
But in reality it just cools the wram air and provides no benefit plus it's noisey. - AVidExplorerPlace the fan control on the thermostat on "AUTO".
About RV Newbies
