Link in original postI have used several filters
Camco: (park hose in-line) caused to much restriction to flow
Britta Pitcher Worked very well till I dropped it one to many times
PUR Pitcher.. What I use now.. Note this is the 2nd filter.
I do a home made activated charcoal (Granual) filter for the whole hosue. no restriction... Can discribe if you wish but.. Nothing special
length of pipe (I used 3" recommend 2) reduced at each end down to garden hose. one end is "Screw in" between the pipe and first reducer is a stainless steel drain cover.
Pack as follows
Filter floss (Fish isle at Wal-Mart et-al)
Pint of Activated Charcoal. the basic stuff not the algicide stuff (Same isle)
More floss
Cap and run water though it till clear.
Hook i tup .
