Jonnygsx's avatar
Jonnygsx
dual battery install, and a roof coating ?
Looking for assistance on a few questions. I have a 98 24lz fleetwood prowler travel trailer. I am trying to figure out how to install two 6v GC batteries. The trailer originally had one group 24 battery installed near the tongue. On my particular trailer there is a large plastic cover over the whole front end including the propane tanks. There looks to be plenty of room on either side of the propane tanks to fit a battery. But there is only plywood wall right there nothing solid to mount them to. If anyone has seen any similar installs or has any ideas i'd appreciate it.
Next im planning to install a 120watt solar panel. My roof is not leaking but it doesnt look to be in the best condition (this trailer is new to me but has seen its use). I was going to coat the roof with some roof sealant. Now would it be a better idea to coat the roof and then install the solar, or should I put all the brackets and wiring up and then coat over them?
Not the best picture but this is looking behind the plastic cover on the front. You can see the black wall of the trailer and then the bottom "floor" of the cover. Obviously there is not strength in the plastic so I feel like something would have to be mounted into the wall, perhaps some kinda tray to hold the battery? But thats still a lot of weight on particle board...
  • Hi,
    Coat the roof with Herculiner.
    Then install the new battery bank at the rear bumper on a rack welded to the frame. Run #6 wire to the OEM connection or to the power center which ever is easier.
  • When I went to using two T105 Trojans I simply filled in my trailers A frame with 2" planking. It's worked well for over 80,000 towing miles.
  • You'll need to support a new battery holder with steel supports underneath. There is just too much weight for any type of attachment to a vertical wood wall. I'd suggest that you remove the bottom plastic piece of the enclosure, weld (or bolt) steel cross members onto the tongue and then replace the plastic shelf. That is the easiest way.
    If it was me, I'd install a locking battery box and move the tanks forward on their own purpose built tank holder. In fact, that's just what I did.
    Roof coating first, then module installation.
