dhulin's avatar
dhulin
Dumb mistake
New RV owner. Was at a campsite and wanted to put fresh water in the tank cause the hose was leaky and we didn't want to leave it hooked up so it would get wet everywhere. Well, put the hose in the wrong spot (flush out). It probably only ran a few minutes, cause I was wondering why it wasn't raising the level in the tank, when water started running out from under the trailer and the membrane underneath bulged out! Luckily inside there was no mess. Toilet just filled the bowl. Nothing leaked after that so do you think everything will be okay or should I get it checked out? Lol - I found out the fresh water fill valve is on the other side of the trailer near the front door!
