whiteeye42 wrote:
first question is the 50 amp plug in the pole barn wired for the trailer or is it wired frow say a welder or a dryer it won't work and it will burn up your trailer because you would be pluging in a true 240 volt plug what you need is the the plug for the trailer which is 2 seprate 120 volt legs so before you plug in make sure it is the right set up.
Uh. Well... If it's a 3 wire outlet yes. but if it's a 4 wire outlet then the outlet I'm plugged into now is 50 amps at 240 or 120/120 volts .
and if it is a 240 volt 3-wire outlet.. The Surge Guard will not allow him to connect. It will fault out on him both brands
