Larryect
May 04, 2014Explorer
Yea, running the inverter from battery, you would need a lot of battery and a large inverter. As stated, anything that creates heat takes lots of power.
As far as the microwave running on generator. As long as both remained on-line, it should have worked fine. Could be something wrong with the microwave taking that long to heat. How does it work plugged into shore power?
Since you have the generator, I would recommend using it when running things like the coffee maker or hair dryer as well as microwave. Just not all at once. Pick one......
About RV Newbies
