pianotuna
May 04, 2014Nomad III
Hi,
Any of the small non computerized drip coffee pots will work, even if the inverter is modified sine wave.
The microwave should run well from the generator you have purchased. Have you checked the 120 volt voltage when running the microwave?
Items such as the fridge, and converter may be running at the same time as the microwave.
About RV Newbies
