- Sport45Explorer IIA rule of thumb is to use the same gear going down as it took to climb up. As long as it's below redline rpms you're not hurting the engine and it does save your brakes. In fact, if you don't use engine braking you are more likely to overheat your brakes and can get into real trouble.
- ScottGNomadNo, I would not break your engine.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
