RoyF
Jun 12, 2013Explorer
If you need 1st gear going up, then you probably also need 1st gear going down. Downhill, it may be IMPOSSIBLE to shift down from 2nd into 1st: you may be going too fast already. It is possibe to shift up while downhill. Better to start in a low gear and see how the car is holding.
Another thing: where is the steepest part of the descent? If it gets steeper on the way down, then you ought not to upshift too soon.
As far as hard/short vs. slight pressure, I have heard it both ways. i'm not sure whether it really makes much difference. But I like to be in a low enough gear so that a tap on the brakes once in a while is all that is required.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
