Gjac wrote:
wing_zealot wrote:
If water gets in, you're likely to have delamination. If water doesn't get in, your chances of having delamination are basically nil.
Delaminations can occur for several reasons, adhesives can be outdated(past their shelf life), the surfaces to be bonded may not be cleaned well(contaminated), dark colors absorbing sun can expand separating marginal bonds. If the pinch rolling process is used out of tolerance pieces to be bonded(low spots) produce less pressure and marginal bonds. Unless you talk to a Tech, Eng or visit each Mfg it is hard to find the information the OP is asking for.
I stand by what I said: "....basically nil"
