JaxDad
Jan 27, 2021Explorer III
DrewE wrote:
I would be somewhat concerned.
The headspace is required due to thermal expansion (liquid propane has a pretty high coefficient of thermal expansion). If you're heading from warm weather to cold weather, it's less of a concern than if you're heading from cold to warmer weather, or sitting unused in a cold place that will get warmer over time.
Please also contact the campground and advise them that they overfilled your propane tank so that hopefully they can provide better guidance to the employee who did that and prevent problems in the future. If they're unconcerned, it may be worth notifying the state; this is potentially a serious safety issue. If the propane expands enough to use up all the headspace, the pressure relief valve on the tank will vent liquid propane, which is a fire hazard; and if the relief valve fails to operate for some reason, there's a very good chance that the tank could rupture, which is an even bigger hazard.
Most tank gauges are calibrated such that when the gauge reads ‘100%k or ‘full’ the liquid level in the tank is at the proper 80% of capacity level. Cars & trucks are the same, when your gauge reads “full” there is still an empty head space above the gasoline or diesel.
Yours is likely working the same way.
Remote reading gauges are also notoriously inaccurate.
About RV Newbies
