MrMark52
Jan 27, 2021Explorer
Land Yachters wrote:
OK, update. I did get the tank filled at CG yesterday on our way out. Figured 24 gal tank and gauge showed 41% and needed to get to 85%, so my limited math skills said I needed about 12 gal. +/- or so. In a hurry blocking exit to CG and guy filled it with 17 gal saying I must have been on empty....didn't look at gauge until I got to next stop, and sure enough, gauge shows 96% full. To get rid of some propane, I am using propane hot water heater, but don't think that will "bleed" off excess propane anytime soon.
Should I worry about 96% fill on tank?
.8 x 24 = 19.2 gallons.
If he put 17 in, you must have 2.2 gallons in the tank.
There is a valve in the tank that prevents filling above 80% (unless you have an ancient tank).
The monitor inside your coach 99% of the time is driven off the tank gauge. So if one is wrong, the other is likely wrong unless there is a calibration setup that allows the monitor to read full at 80% fill (which is a true reading of tank capacity).
About RV Newbies
