BarabooBob
Oct 01, 2020Explorer III
I had an '88 Toyota Escaper. Do you have a true one ton dual wheel full floater axle or do you have the lighter duty axle with foolie (fake ) dual wheels.
Either way, you do not have to remove the entire rear axle assembly to do a brake job. You do have to pull the axle out of the housing to get things apart. Find any good mechanic that works on trucks and they will be able to do the job. You mechanic may not know what he is doing so finding someplace else is a good idea.
Many of the older (ralative term here) had the original rear axle replaced with a full floating axle. If you have 5 lug front wheels and 6 lug rear wheels, this happened. It was a fix to a problem that Toyota paid for.
There is a web group that specializes in Toyota based RV's. Go to http://toyotamotorhome.org/forums
Those people have a correct answer to every question you can imagine. They helped me through many problems.
Their forum currently has a conversation going on about brakes and suspension repair in southern WI. This is the link http://toyotamotorhome.org/forums/index.php?/topic/12293-wisconsin-mechanics-somewhere-between-madison-and-milwaukeeor-maybe-northern-illinois-near-the-wisconsin-boarder/
You can send me a personal message and we can talk. If you wish, pm your phone number and I will contact you.
About RV Newbies
