mrjack wrote:
bikendan wrote:
mrjack wrote:
Old-Biscuit wrote:
Do you have the proper truck to carry the pin wet of that 5th wheel?
 no, haven't even look for the truck yet. what can you tell me about this
look at truck's PAYLOAD first, then its towing capacity.
you need to post the specs of the Montana or at least which year and model you are thinking of buying.
as to used or new, we found that many RVs are as cheap new, as what some people want for their used RV.
the model is 2016 Montana 3791. I was told by a friend that I should buy a Ford or Chevy Diesel Dual wheel 350. My son thinks a Ram 1500 Diesel would work just fine, do you agree?
your son is VERY mistaken!:E Nor sure what he's been smoking.;)
DRY hitch weight is nearly 3000lbs. it has 5 slideouts and is 42' long.
listen to your friend. a SRW 1 ton might work, depending on payload.
