That will be a nice trip! Plan on leaving very early in the morning to get off the island. The Cross Bronx gets awful after 6 am! The BQE is hair raising for any rv. Once you hit Jersey it will be a lot better. Make sure you reserve your spot(s) as far in advance as you can. Ask the campground if you need to leave something in your site while you are gone as some will see an empty spot as available. As mentioned above, common sense tends to prevail when figuring what should and shouldn't be done in a campground. Just imagine the way you would expect those around you to act and you will be ok. Have a great trip!
