1. Walk the site before backing in. In the process of backing, if you are unsure, stop, and walk around the rig. Remember to look up as well as around the rig.
2. You level the trailer side to side while the rig and tow vehicle are connected. You can use boards or lynx level blocks under the wheels on the low side. You level the trailer back to front after you disconnect, by using the tongue jack. Don't forget to bring a level with you.
3. Make sure you use a pressure regulator on your fresh water hose. I shut the water off at the spigot when leaving the trailer for sightseeing. You don't want to come back to find a leak has been filling your trailer with water.
4. Make a small toolkit for the trailer. Start with teflon plumbing tape, and slip pliers. Also the right wrench to fit your water heater plug, and other fittings on your trailer. This is a work in progress. zip ties are always a good idea.
5. Before you leave from home or camp, and you think you are ready, walk completely around the rig and give it a critical look anyway. I also do this when I stop for rest or gas.
6. Most of all, enjoy!
