Redwhitenblue
Dec 30, 2015Explorer
Thanks for all the valuable responses, I'm learning a lot.
From home where we are leaving, to the destination, and back will all be most likely below freezing temps, but not lower than maybe 10* or so.
I don't know if we will have water hook ups or power, we do have a yamaha 2000 generator, 2 6v batteries in series, and 5 gal of extra fuel for the genset.
The dealer said that the there is a belly pan on this model and the tanks are insulated so as long as the coach doesn't get too cold nothing will freeze, but then to drain everything, and winterizer before traveling back home to store it.
I understand from your responses that I likely have a water heater bypass so I'll search for that.
I also understand to never put antifreeze the in the FW tank.
I guess my question is if I'm going to be dry camping, which means I need to fill up the FW tank at home before traveling, it seems I would need to run the heat in the coach to make sure the pipes don't freeze during the travel if I can't flush out the pink stuff at the destination due to no water hookups.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
