Bipeflier
Jan 01, 2016Explorer
If you are going to be below freezing for the entire trip I would not de-winterize. Do not use the FW tank or plumbing at all. Use bottled water for everything and do not dump into the holding tanks. Take "back packing" baths (heat a little water and just wash off).
If you try to use the on board plumbing (shower, toilet, etc.) you will likely run into freezing up. Don't risk it.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
