dodge guy wrote:
Well, better continuity to the cable would be the new antenna. I used all the existing cable and switch plate with the same power injector. The only difference is the antenna. Digital antenna or not the Jack antenna is a far superior antenna IMO!
Glad it's working out OK for you. By continuity, I meant that by just changing the antenna you might have overcome a loose or corroded connection. There are many posts on this Forum about users switching from one antenna to another and getting miraculous results.
It all can't be from changing the antenna as not everyone that changes is picking the same antenna.
