TXiceman wrote:
The Majestic UFO appears to be a omnidirectional antenna with a high gain amplified. The problem is with a weak signal that is amplified, the noise is often amplified as well unless there are filter circuits to knock out the noise.
The UFO will probably work OK in a strong signal area, but will not perform as well in a fringe weak signal area.
Ken
And I know you know this, but for the benefit of mdamerell, you also have zero control over multipath (reflections) from buildings, mountains, ducting through canyons, etc., that no amount of gain can fix, and often makes it worse.
An Omni-directional antenna on a boat is a completely different animal. Don't let the salesman fool you into believing they aren't.
