Wishbone51 wrote:
Rick57 wrote:
If you keep your sewer valve open and not allow the waste to stay in the tank...
Isn't that the first no-no you learn when RVing?
Hello Wishbone51
Yes it is better to keep water in your tank then release before you leave or when it is full. Still have to rinse the tank with fresh water. Some use the shower head to refill the tank. I forget not every RV has a rotating rinse inlet like mine has. I guess the main thing I was trying to pass on is leaving 2 in of water in the bowl leaves a barrier to help hold the smell at bay.
