Old-Biscuit
Apr 25, 2014Explorer III
You will need to un-seal the dinette and access the tank so that you can check if tank is cracked, fill line leaks, overflow line is not connected, vent line leaking.
IF all connections are done right.....tank should NOT leak inside rig even IF you fill too fast..it should just burp back on you thru fill line.
As the contractor how to access the tank. Something is NOT correct.
About RV Newbies
