It sounds like the pump is cavitating (full of air). It hasn't picked up water from the tank for some reason.
Things to check:
1) Is the water heater full of water? If no, you will have to pump 6 or 10 gallons to fill that.
2) Open a faucet to allow the pump to push air out of the system.
3) Is the winterizing valve for drawing anti-freeze into the pump in the proper position. If not, you are drawing air through the winterization hose.
4) Less likely, the pump is worn out or the pick up in the tank has fallen off.
Good luck.
