Bird_Freak
Apr 18, 2016Explorer II
Aron wrote:If you understood how your propane system works you would not be afraid of it. if you are in a wreck and a line is severed the valve in the tank is going to shut the flow off anyway.
I think the reason that many people caution about using propane while traveling is that if you have a wreck, you might then also have an explosive gas-fueled fire to add to the excitement. Could make what would be a very bad day that much worse. Personally, I'd rather play it safe and deal with the variable temperatures.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
