handsome51
Jun 09, 2017Explorer
schl44 wrote:
Hi,
I just had a 63 gallon RDS auxiliary fuel installed in the bed of my 2012 F350. After instalation was completed I asked how many Gallons Per Hr this Posi-Flo pump would put out. I was told it was 7 gallons per hr. Is this pumping capacity high enough? It seems to me the flow rate is not high enough and Im concerned It will be overworked and burnout!
Thanks, Lee
Here is what I did. I put a 37 gallon RDS diesel tank in front of my tailgate in late 2006. I installed their set up in my filler neck so it could gravity flow to fill the main tank. But since it was made to be over the main tank not in front of the tail gate. Flow was slow. It could keep up without pulling the fifth wheel. But with the Fifth wheel and 8.8 mpg, it could not keep up. So I installed a electric fuel pump in between. When my gauge moved down , I flipped a toggle switch and filled the tank back up. Her is the kicker. I bought a small fuel pump from auto zone to install and bought a spare. I have used these types of pumps since the 70s and have never had a problem with them. Exactly 9 months later on a trip it did not work . So at the RV park I installed my spare. Even though I have not had a problem before ,does not mean one can't go bad. Then exactly 9 months later it went bad. I had bought another spare when we got back home 9 months ago when the other one went out. I put the spare on but found out what the problem was. The package had Made In China on it. I went on the internet and found a pump Made In The USA on it. Same bolt holes and line fittings. A exact bolt in install. I did not wait till the made in china pump failed 9 months later. I installed that made in USA pump in the spring on 2008. It is still on the truck working fine. The pump is a Facet®CUBE®Solid State Fuel Pumps . They have 3 different square models.Depending on the gph you need Can pump up to 50gph.The website to look at and read the pdf file on them is: http://www.facet-purolator.com/cube-fuel-pumps.php
About RV Newbies
