Grit dog wrote:
JaxDad wrote:
TjMurphy002 wrote:
The biggest questions I have are about insulation, keeping the pipes from freezing, and maintenance.
Thanks in advance!
A pilot friend who lives in a very cold area of northern Canada finally gave up on commercially available RV’s and built his own. He says the difference is night & day!!
It is if I recall correctly, 8’ X 24’, built with a 2” X 4” frame with spray foam insulation, residential windows and steel cladding. Heat is from a pair of diesel-fired truck heaters. Plumbing is all PEX tubing designed to be blown clear on a regular basis.
He says from both a quality and efficacy point of view he has a *far* superior product and at a far lower cost to boot.
I’m sure it’s very cozy! And likely very well built.
But that’s a huge undertaking in the context of the OP and something I don’t get the feeling is a reality for him, on multiple fronts.
Big question is what’s your buddy’s camper weigh? I could see maxing out a 14k 24’ flatbed.
He built a tiny home and a good one by the sounds of it.
There are some good suggestions here, contrary to my last tongue in cheek response.
But unlike some who like to just come here to pontificate or think outside the box or not consider the whole picture when making a suggestion, I try to do none of those things as the most helpful response is the most honest thought out one!
It was built on-site by a local carpenter on top of a cut down 8’ park model frame, he said it weighs about half the GVWR of the frame, roughly 5k pounds. He said he was originally go with 8’ X 16’, the largest prebuilt garden shed available, but the carpenter pointed out to him that the over-priced commercial product would actually be more expensive than the 8’ (50%) longer custom built product.
