parkgt wrote:
pianotuna wrote:
Hi,
Bump up the battery bank and add an inverter. Put some money into solar. At 600 watts there remains no reason to run the genny unless using the roof air conditioner.
For many that is not an option. My Sprinter only has room for 180w panel and two group 31s.
One could add two 100 watt panels on the ground in a fold-out kit to that 180 watt panel permanently mounted on the roof and have a pretty decent set up. Being able to place and aim those ground units goes a long way toward making them maximally productive. While 380 watts might leave you not-quite-fully-charged, they could certainly make it possible to delay the generator for 3 or 4 days.
The little 1800 watt inverter generator I used for many years bit the big one last fall. Looking into what to do about that, I found solar made a lot of sense. Since I've only a single battery, 200 watts in the form of a pair of 100 watt panels I could carry in the TV and put out on the ground, were adequate for fully recharging my battery. The up-front cost was pretty much a wash with the cost of a replacement generator, and a huge savings when you factor in gas, oil, spark plugs, etc. for the next 25 years. I will eventually mount them permanently on the roof, probably adding a couple more, when I upgrade to the lithium iron phosphate battery I now covet.
Do the math. My TT's converter delivers only 35 amps to charge the battery. That's only 500 watts charging power. The rest of the generator's 1600 watts was excess (and unused, since it's not enough to run the AC) capacity. To get the 1,000 watt hours of battery power I go through in a day takes shore power (or the generator) 2+ hours to replace. Over an 8 hour useful charging day, you only need 125 watts of effective solar power for the same result. The OP's case is probably different, but the gist would be similar.
Solar has gone beyond cost-competitive with a generator. The only remaining frontier here lies in running that AC.
