dieseltruckdriv
May 12, 2020Explorer II
Taxman2436 wrote:
Thanks for all the responses. I’m leaning toward the Honda 3000 because it will run everything but my concern is the weight. I hadn’t thought about pairing up 2 of the 2000’s. That is worth consideration. How long will they run on a tank of gas?
That depends on what you are going to do with them. If lightly loaded, one of my Honda 2000s will run just shy of 15 hours, the other one will go well over 12 hours on a tank of gas, which is about a gallon. As far as I know Honda is the only one that will let you use an extended run tank which is important to me when the weather is bad and the solar doesn't do anything.
About RV Newbies
