- patchelectExplorerYou could be right about the 2800KW, but if you made a mistake and it wasn't large enough you'll find ways to double joint your knees to kick yourself in the tail!
And the inrush (starting) current on any electric motor is generally THREE times the rated running amperage. It may only be for a nano second, but that could be the difference between "Ahhh" and "Ah CXXP" - tatestExplorer IIIf it is the Coleman Mach series, the manufacturer recommends 3.6/4 KW, for the protection of the A/C from low starting voltages. Yes, the 15K goes on a 20 amp branch circuit, draws 14-17 amps running, but might double or triple that briefly while starting the compressor.
Hooked up to power, this is a surge and brief voltage drop. Hooked up to a conventional genset, this surge is handled by trading rotational energy for extra power, slowing the generator briefly. Inverter gensets, if large enough, might not even sag the voltage (if not running in economy mode). Some will overspeed to briefly supply more than the rated power. In either type, the protective circuitry in the generator has to allow the surge, and if sized too small the surge will prolonged and the generator more likely to disconnect or even shut down.
I know campers who have gotten away with using the Yamaha EF3000ISEB for a 15K A/C, while the EF2400IS (nominally 20 amps) couldn't handle an A/C that large. One brand might work while another might not, and within brands, different models of the same nominal size have different surge capabilities. In the smaller sizes, it is best to look for something offering a "boost" feature. - nickthehunterNomad III
moresmoke wrote:
The only problem with that theory is that I am pretty sure that AC is on a 20 amp breaker or less; it may be on a 15 amp breaker. If the TT wasn't in the storage yard all wrapped for safe keeping for the winter I would go check it out. But I'd be willing to bet dollars to donuts the breaker ain't more than 20 amps.
According to Champion a 3100i will handle a 13.5K and a 3400i will run a 15K A/C. So for those two models of generator, I would be tempted to follow the manufacturer's advice.
I think the 3100 may do it and turn off the AC before starting the microwave.
On paper, a 2800W could even work. I could be tempted to try that out. - moresmokeExplorerAccording to Champion a 3100i will handle a 13.5K and a 3400i will run a 15K A/C. So for those two models of generator, I would be tempted to follow the manufacturer's advice.
- SoundGuyExplorer
tatest wrote:
When my women start running their morning grooming and breakfast appliances it is usually a tossup whether the 30 amp breaker in the RV or the 30 amp breaker at the power post is the first to go. They blow breakers in my house too, usually too much on a branch circuit, as in trying to blow dry under the heat lamps.
Time for a little "edumacation" on the subject of power management. :W - tatestExplorer II4KW. It can run with a coffee pot, toaster, small RV microwave assuming the A/C is running and not trying to start. It might not run a blow dryer and curling iron at the same time as the A/C is running, that combo can be a heavier load than RV microwave (and coffee maker loads depend on what point in the brewing cycle).
With 4KW of genset, the 30 amp main for the whole RV is likely to pop before you overload the generator. Your house limit is usually 3.6 KW.
For the A/C alone, Coleman sets 30 amp service, 4KW genset, as minimum for their 15K BTU/hour A/Cs and heat pumps. Brief starting loads go 2-4 times that capacity, and only the larger gensets have enough spare rotational energy to handle the overload. - theoldwizard1Explorer II
nickthehunter wrote:
How big of a generator do I need to run my 15K BTU air conditioner? Assuming I may also be running a coffee pot or microwave at the same time.
If you insist on running all 3, you are going to need a >3,500W ! - 2gypsies1Explorer IIITurn off the air if using the microwave or coffee pot. Also... there are excellent stove-top coffee pots. They make great coffee.
- Isaac-1ExplorerThere are a lot of it depends,but I can tell you the 4000 watt Onan Micro-quiet (yeah right) in mine will power the 13,500 btu air conditioner and the mircowave / convection oven either in microwave or convection mode at the same time. Can't help on the coffee pot though as I rarely drink the stuff.
- The_real_wild1ExplorerGo with a 4k or bigger.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
