naturist
Apr 05, 2017Nomad II
swimmer_spe wrote:
Would 2800 watts be enough?
Once I know what wattage to go with, I will shop around.
Short answer: NO.
2800 watts will run your AC and maybe a couple lights. Hit the microwave, however, and it'll choke, guaranteed. That size will be running close to capacity whenever it is running (up until it kicks off because somebody decided to make popcorn, or turned on one too many lights), which is not a prescription for longevity.
As somebody else pointed out, a trailer with 30 amp service will require a 3600 watt generator to supply all 30 amps. That's just how it is. If you really want to be able to run EVERYTHING at once, go for a 4,000 watt generator.
About RV Newbies
