CharlesinGA
Nov 03, 2018Explorer
Be mindful of the length of the trailer you select and the problems being "too long" can cause. The longer a trailer, the more sway issues you can expect.
I have read several places on different discussion forums of two different rules of thumb to consider. (hope I get these right)
1) A wheelbase of up to 113 inches is good for a trailer length of no more than 20 ft. for every additional 4 inches of wheelbase, you can add a foot of trailer length.
2) The distance from the ball to the centerline of the back most axle of the trailer should not be more than twice the wheelbase of the tow vehicle.
Pay close attention to where the tanks are located, especially the fresh water tank. Too far aft and you may have to tow with the FW tank empty and fill at or near your destination. Some trailers are poorly configured and much consideration should be given to tongue weight and making sure you will have enough of it.
Charles
Charles
About RV Newbies
