5thwheeleroldman wrote:
I've considered an extra diesel tank as the Duramax only has a 26 gal tank. I worry that the extra tank would not be safe in an accident. If the worst happens and you are upside down with diesel pooling around you --- not good. Course, maybe it could happen with the factory tank too.
Titan and Aero Tanks make aftermarket fuel tanks that replace the factory tank and provide over 60 gallons of capacity. They fit most GM trucks though not all.
99% of the gas stations in the west did not pump diesel 10 years ago. Now with more diesel burning cars this is changing. On our last trip I found Shell gas stations that not only had diesel at the gas islands but also a DEF pump. With the truck stops we had to use the high volume large DEF nozzles with our Duramax that has a very small fill opening. With the Shell DEF pumps at the car islands we had a small nozzle and a much slower fill rate.
To only buy diesel at truck stops is not feasible for most people as they are only along major interstate highways and who restricts their RV travels to these routes? We avoid the interstates as much as possible.
The DEF at the pumps is going to be fresher and in better condition and cheaper than buying it at an auto supply place. You can also fill up the tank and not carry around a partially filled plastic DEF container.
