Plan_B_RV
Mar 06, 2019Explorer
Good boon-docking RV with good ground clearance?
Question: Could you give me example of good clearance RV that you have used or seen to boon-dock?
I have plan to buy huge 5th wheel with bad ground clearance and try to boon-dock.
I will have to increase ground clearance:
from 12” (Angle of departure %7 AKA 12.5 slope)
to 24” (Angle of departure %14 AKA 25 slope)
I could try to calculate clearance and angel of arrival/departure based on your RV suggestion. Then compare to 5th wheel and decide if my plan is sound.
Extra info if interested: Plan to flip axle + slightly bigger tire= extra 6” of clearance.
Plus airbag suspension pumped up to max. when off-road. Hopefully another 6” increase. Totaling 12” extra. But since rear overhang on 5th wheel over 90”, even increase of 12” sounds not enough.
On other hand, I will be towing illegally in most states because 5th wheel height 13.5 feet. By adding 6”, I will make RV height to 14 feet.
