SDcampowneroperator wrote:
Grit dog wrote:
Take the camper somewhere out in a field, open the gray valve and snake the line. Stand off to the side!
Depending on how much grease you’ve dumped down the sink over the years, could be a good layer of grease in the whole tank, like as tall as the drain pipe?
I’d go after the remaining grease probably 1 of 2 ways.
1. Figure out how to get a large quantity of boiling hot water into the tank. Quick drive to slosh it around. Drain in that field again.
2. Couple gallons of something like Zep industrial cleaner/ degreaser dumped into an empty tank. Drive to slosh, drain into a sewer preferably.
. Do not do this,
That field is ours or someones, land! or an absorption sewer system biologically destroyed with the in flux of grease and solvent. Please No Do Not Do It! in a small wastewater system.
If grease is the cause of your problem do the treatment at a municipal plant that has the bugs to eat it.
Oh my gosh. Please look at the potential environmental impact of what you're commenting about. Then think about the millions of people, septics, sewers, overflowing grease traps in every city, (likely) thousands of gallons of fuel spilled daily, etc etc.
No one is suggesting making a public dump for all to use in your back pasture. And please don't insinuate the "what if every one did this" argument because this is 100% not the case.
1. It was a suggestion.
2. This is so micro minuscule in the big picture it's indiscernible.
3. Where do you think all the gray water goes from every campground and home septic/sewer system? Same place just starts out a couple feet underground.
Ever dump some bacon grease off the back porch instead of down the drain? Ever clean a shop floor with some degreaser and rinse it out? Well if you haven't, millions do. What happens if you dump that grease in your garbage can and it goes to an old landfill or dump? Is that better, or is it out of sight, out of mind.
Merry Christmas!
