brholt
Jan 07, 2014Explorer II
Guysakar wrote:westend wrote:
Truck with slide-in will be the most maneuverable. I know someone will post that they take their Class A off road with no problem but that is probably across a gravel road that is flat and has no obstructions. I think it's a wash, basically, between C and A with ground clearance.
Looked into truck slide-ins and they're just too small.
To small? Someone with a triple slide Eagle Cap, Host, or Chalet might disagree with that. :). Compared to Class B's and many small Class C's many of the current larger truck campers have more space and much bigger tanks.
Given your budget those are probably out. I think you are going to have a lot of trouble finding good ground clearance in anything but an off-road pop-up or truck camper. They are out there but nominally pretty expensive, e.g. 4x4 Sportsmobile. Your best value if you need a lot of space is going to be one of the off road pop-ups.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
