westend
Jan 07, 2014Explorer
Another tactic might be to tow a small truck with cap behind the Class A. Use the coach as base camp and explore with the truck or use it for day trips. Anyway you go with a Class A is probably not going to be cheap. If you buy very used, you'll chew up dollars doing repair and maintenance.
If you're set on the room and amenities of the Class C, that is probably the way to go. It may limit you, somewhat, on exploring rugged back country but there are a lot of good wilderness roads out there. In my area, width of trail and overhangs are more the limits than condition of the road surface. Where are you located and where do you plan to go? There may be some members that could narrow your choices because they have intimate knowledge of the camping areas you plan to visit.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
