saffikeagan
Apr 14, 2019Explorer
ken56 wrote:
If those batteries froze solid and the sides are bulged even slightly replace them. The plates suffered damage and failure is in their future....at the most inopportune time. Plugging into shore power should provide 12volt power through the converter so the battery should not be necessary to be hooked up at the same time.
Your only complaint was the CO detector, but everything else worked correctly? Furnace being the important thing in the cold weather. If that is the case then everything indicates the fault is at the batteries. To remove batteries disconnect the NEG first, to reconnect connect the NEG LAST.
Yes, everything else was working fine. No bulging on the sides.
About RV Newbies
