bid_time
Apr 14, 2019Navigator
You need to disconnect those batteries any time you will not be using the TT for more then a few days. Parasitic draws will continue to discharge those batts when not in use. Repeatedly discharging the batts is not good for them and will cause you issues. Get a disconnect switch, install it and use it.
About RV Newbies
