smarty
Oct 14, 2020Explorer II
Assuming your rig is fully enclosed since it is a van? Would therefore assume your heater will keep all pipes internal to the van from freezing? Disconnect water supply before going to bed and you should be good to go? If the water supply is a "short run" you could also use a heat tape on the water line and be okay depending on how cold it gets. Could also easily wrap the line/heat tape with some type of foam pipe wrap.
About RV Newbies
