- StefoniusExplorerI think that a large part of the problem is the color temperature of the lights. Old style headlamps burned at about 3500K, which is a "warm white" light that appeared somewhat yellow. This is just fine for the light-sensitive rod cells in your eyes and won't mess up your night vision. Newer lamps are often in the 5000-6000K range, which is more of a "daylight" color that appears whiter because it contains more blue. This overwhelms your rod cells and makes you rely on the cone cells that normally only see use in daytime. Once the lights have passed, you'll find yourself blinded until your rod cells recover and restore your night vision. If the DOT was smart, they'd outlaw headlights over a certain color temperature and enforce the rule.
- paulcardozaExplorerAs with most everything else on the highways today, there are issues about what is legal vs what is enforced! I see pickups with 20" led light bars running the highways all the time. Certainly these are sold as OFFROAD USE only, but I doubt they ever get pulled over here in MASS.
During rush hours here in the Boston area, I cannot even remember the last time I saw anyone pulled over at all, except for the SP protecting someone while changing a flat tire.JaxDad wrote:
1320Fastback wrote:
Last I checked California is 6 uncovered clear lights facing foreward. Light bar counts as one.
I don't believe any jurisdiction in NA allows more than 4 lights facing forwards, that's why OEM foglights go out when when you put on the highbeams on a 4 lamp system.
As for auxiliary lights in California, they can only be mounted a maximum of 42" above the road, spotlights may be mounted higher, but can't shine to the left of the vehicle nor more than 300 feet down the road nor light up another vehicle nor be more than 30 watts incandescent equivalent. - JaxDadExplorer III
As for auxiliary lights in California, they can only be mounted a maximum of 42" above the road, spotlights may be mounted higher, but can't shine to the left of the vehicle nor more than 300 feet down the road nor light up another vehicle nor be more than 30 watts incandescent equivalent. - drsteveExplorerAll headlights/fog lamps used on public roads must be DOT approved, the state has nothing to do with it.
- Sam_SpadeExplorer
Songbirds wrote:
But here in Florida is A OK with as many head lights and fog lights you can burn at one time.
I think that is absolutely wrong. Especially for light bars that are clearly labeled "For off-road use only."
Unless you can back up your opinion about that dangerous and irresponsible behavior with a quote from a State statute, I suggest that giving out bad information is not a good thing to be doing. - john_betExplorer IIThey are to bright for me also. Whether they be factory or added by owners as after market in older vehicles, especially LED's. Also some cowboys around here use the off road LED bars as added lights and 95% of the time do not shut them off when they met oncoming traffic.
- 1320FastbackExplorerLast I checked California is 6 uncovered clear lights facing foreward. Light bar counts as one.
- SongbirdsExplorerYOU are correct and the LAW says it's not a problem. So down here in Florida they will install a Light bar across your Hood, roof and between FOG lights and NOT a problem in Florida as many drivers here drive with FOG lights on. State of Florida could care less if oncoming traffic cannot see the road as long as the NUT Job with his or her new installed three 12-inch light bar is on a dusk. Now, something NEW is 18-wheelers running with side LEDS if you try and pass them on the right on a three-lane Highway they will flip it on and it's all OK, because they need to light when backing up. So I was thinking of putting them on my RV and my wife overruled me saying NO. But here in Florida is A OK with as many head lights and fog lights you can burn at one time.
- Mr_Mark1ExplorerJfkmk said: "I don't think the troopers have as much an issue of you flashing a truck indicating it's safe to get back into the lane as flashing oncoming cars to warn of a radar trap."
That would make sense.
MM. - AnonymousNot applicableMy new truck won't let me keep my brights on during the day. It has sensors that won't turn on my yellow side lights until it is dark enough outside. I'm assuming this also controls the ability to leave my brights on.
About RV Newbies
