ok Brand of Fridge is a dometic fridge
water heater know idea what brand or model i do know that i located it and there is only one cut off switch on the cold line running into the WH so i do not have a clue how the bypass winterization process would work.
i am on 15 amp shore power now
the battery on the incicater light shows C i am assuming charging?
I do now know the brand of inverter i have on the battery
I think the fridge problem will deal with its self after 24 hours.
a question from the wife though
can you use a powerstrip (i.e.belkin surge protector ) in the rv to charge phones and for a cpap machine etc. ?
Can some one give me the name of a local tech in the area of north alabama cause i dont have a clue who to call. i hope that covered every ones questions.
