wa8yxm
Apr 15, 2021Explorer III
I would say remove the ball from the Truck thenput the hitch and the ball on the bench, upside down. so you can get a good look at the blanged thing.
Odds are a couple tapps with about a 12-16 oz hammer and perhaps a rod to direct the force and it will pop open and release the ball. then you can either put the ball. or more than likely a new ball of the proper size on the truck. (Inspect the bolt threads often they get damaged so you need to use a new ball.)
About RV Newbies
